where is the frequency VI for a computerboards card
i have a ciodas08 computerboard daq card i use labview 6.1 with the universal library for labview i coudn't find the vi that i can use to measure and watch the frequency of an input on a graph?do you know its name and where i can find it thanks in davance
(2,958 Views)
If your card has a frequency counter on it, you should ask ComputerBoards if they have a function for it. If you are digitizing a signal, then you can use Extract Single Tone Information on the Analyze>Waveform Measurments palette.
(2,958 Views)
hi Dennis thanks for ur reply i searched for the wavefor measurment function under analyze but i didn't find the "analyze" icon on the functions palette do you have any idea why?
also i found some functions like add wavefore,substract wavefore,search waveform,but what i need is measure the waveform ,i need something like the fft vi of the labview.
thanks
(2,958 Views)
The analysis functions are the dividing line between the base package and the Full package. I am guessing that you have the base version of LabVIEW.
(2,958 Views)
What version of LabVIEW do you have and what package (base or full). I don't think any of the fft based functions come with the base version. If you have a Waveform palette, do you have a Waveform Measuremtns sub-palette under that. The Extract Single Tone function can also be found there assuming you have at least the full LabVIEW version.
(2,958 Views)
Dear Dennis,
i sent to computerboards technical support i hope they would reply , i sent once to them and they never replied also i don't know why they don't have a discussion forum as the National Instrument ,actually i was wrong to buy a DAQ board from the computerboards product it's cheaper but i am lsoing my time since there in no technical support .
i have Labview 6.1 base version with the universal Library for Labview i bought in may 2003.
do you think what should i do?
thanks Dennis ,and all who replied to me
(2,958 Views)
