whether I can change the backcolor of tree control
tree control has the white backcolor,hoew to
change it? from the property node ,I can not
find a valid way.
(2,620 Views)
I can't seem to change the background color of the whole tree, however you can change the color of a cell using the "active cell>>background color" property. So it is not elegant, however you could go through and set all the cells color.
(2,620 Views)
