whether it is possible to drive a stepper motor from speedy 3's output
actually i am trying to design an voice controlled wheel chair for my application wat i have did is tat i have writern two programs using labview one is just storing my voice for four commands(namely front ,frontright ,frontleft,stop) ,tat  it stores some value in an array, in my second vi i am speaking one of the four commands, and tat comands amplitude is stroed in an array and i am just comparing it with the values from the first array which i have stored it for all the four commands if any of the array value matches just approximately the i have to make the stepper motor to drive in tat direction i have done it with PIC microcontroller can u give some directions to implement using speedy33
(3,295 Views)
(3,272 Views)
no sir just now i saw tat ,i have completed almost 75% of the project what i have did so far is tat  i have just writern the two programs and i have done using serial port in labview and i have programmed the microcontroller also. wat i am trying to do now is to upgrade my project using NI SPEEDY33 while doing tat i got the doubt whether it possible to drive a stepper motor from speedy33's output
(3,245 Views)
sir please give some guidance
(3,244 Views)
The SPEEDY-33 Robotics Daugher Module is an add-on device that mounts onto the SPEEDY-33 to provide more functionality. It includes:
  • DC Motor Drive Outputs (4)
  • Auxiliary Servo Motor Outputs (4)
  • Analog Inputs (4)
  • External Power Supply Connection
Details of the daughter module, you cn find at the link below:
http://digital.ni.com/public.nsf/allkb/832F1F4B12ECE1BE862572D100765898?OpenDocument
This daughter module is NOT an NI product.
For connecting a stepper motor, since speedy 33 has digital outputs, it is possible to work a stepper motor. However, you will have to connect a stepper motor drive inorder to amplify the signals to the current specifications that the stepper motor demands. Find out the specs of your motor and choose an appropriate drive.
Mithilesh Pradhan
(3,229 Views)
