which driver software is required to drive NI 9485 Solid State Relay
I want to use NI 9485 SSR in my project. Which driver software should I use?
Also, what are the precautionary measures to be taken while connecting NI 9485 to a 24V / 500 mA, solenoid to it (9485, for switching action).
Thank you... Help appreciated.....
(2,698 Views)
It is a compactDAQ product, so you should be using dAQmx drivers.
Beyond that, I would read the instructions and see if it points out any special precautions.  Often you will want to put a diode across the coil of a relay or solenoid to prevent damaging voltage spikes or currents from destroying the DAQ device when it switches off the coil and the collapsing magnetic field of the coil reverses the current back to the DAQ device.
(2,683 Views)
