who is the forum administrator?
The help text says "For additional information or unresolved Forum Problems, please E-Mail the Forum Administrator", but gives no clue as to an email for said "Forum Administrator". How should I contact them? Note, that in this case, I don't believe that "in the forum" is an appropriate answer.
Bruce
(2,566 Views)
Bruce;
I believe Molly K. is (one of) the main manager(s).
You can post this same question in the "Feedback on NI Discussion Forums" forum. Check this thread.
www.vartortech.com
(2,540 Views)
If the "unresolved problem" is with a particular post, click on "options" in the upper right corner and select "Report to a moderator".
You'll get a new window with a text box where you can voice your concerns. Always worked well for me! 😉
(2,530 Views)
Enrique, thanks for the pointer to Molly, and in particular the thread you pointed to. The "issue" I had appears to be know (really crappy xlation from forum to nntp). No indication of when it will be fixed, but at least it's known.
(2,523 Views)
