why I can't scale the x-axis of my waveform!!!!!!
I am using NI USB-6009 DAQ to observe the sine wave generated by function generator. However, the waveform always stops at 1 of x-axis although I had scaled it to a maximum of 2. I hope to see more sine wave on my graph. Anyone can help me?
(2,735 Views)
Use a chart instead of a graph Smiley Wink
(2,707 Views)
but when I right click, I got the graph under the create->graph indicator. How to chose a chart instead of gaph??
(2,684 Views)
(2,684 Views)
Hello Weikeong,
You will have to add a chart to your front panel (using the controls palette) and then make the connections on your block diagram.
Happy Holidays!
Janell R | Applications Engineer
(2,666 Views)
