why SCXI chassis doesn't get recognised for PXI1010 in LabviewRT7.0
I'm working in LabVIEW-RT7.0 with NI-PXI1010 Daq system..as a Remote system...with labVIEW7.0/RT..etc loaded on a compaq laptop. I can work with NIsystem as a standalone..but when connect it as a remote Pc via..ethernet to a Host Pc(Laptop0 i'm not able to configure the system..!! The SCXI modules configuration is not being done using NiDaQmx..chassis configuration.The Chassis Communicator textbox & Communicating with SCXI moduleslot text box in the CREATE NEW SCXI CHASSIS Section of Devics & interfaces are disable or greyed out & gives an error check PXI help in MAX!!! Please let me know how to do the configuration!! in RT from a Host PC.!!!
(2,526 Views)
NI-DAQmx is not supported by LV RT 7.0. You must use Traditional NI-DAQ 7.0 to incorporate data acquisition in real-time applications.
Luca
Luca
(2,526 Views)
I forgot this tutorial. It explains how to configure a LV RT/DAQ/SCXI System:
http://zone.ni.com/devzone/conceptd.nsf/webmain/5323DC2D1AD0DB8086256BAD00760C19?opendocument
Luca
Luca
(2,526 Views)
