why am i getting error --20061
why am i getting this error and how can i fix it.
Message 1 of 10
(7,538 Views)
The selection is invalid
That doesn't help me any.  Do you have a screen shot of the pop up error window?  It should tell you where the error was thrown.
Message 2 of 10
(7,534 Views)
he is a picture of it.
Message 3 of 10
(7,526 Views)
Accepted by reggie2016
Nevermind, I found it.
Your problem is where you are bundling up the sampling info for the Basic Function Generator.  You have the items switched (the sample rate goes in the top).
Message 4 of 10
(7,525 Views)
thank you
Message 5 of 10
(7,519 Views)
I am have the same problem what do you exactly mean?the signal generator is not conneccteed properly or?
Message 6 of 10
(4,037 Views)
Hi NP,
So after 8 years the same problem with the same VI?
Maybe!
why don't you attach your own VI so we can actually debug your code for you?
Message 7 of 10
(4,032 Views)
Message 8 of 10
(4,030 Views)
I am using 2 picoscope and 1 BK4053 signal generator
Message 9 of 10
(4,026 Views)
Hi NP,
because sine frequency and samplerate must fulfill the given relation.
I guess your VI does not fulfill that requirement…
Message 10 of 10
(4,019 Views)
