why can't I hide labview exe
I'm trying to spawn a labvie exe app from a visual basic app.  I use the shell command to execute the labview app.  This works fine except that I'm using the "vbhide" attribute that doesn't seem to work for the labview app (it works for other spawn programs).  I then followed some of the suggestions I found in the forums about using the front panel property and hide the window.... that kind of works but you can still see the window briefly flashing on the screen before is hidden.  I don't like that.  Has anyone run into this problem before?  Any solutions?
(3,473 Views)
Accepted by nelg87
You can go to File->VI properties, select 'Window Run-Time Position' catagory and set position to minimized.  It will appear on the task bar, but it won't flash.
(3,455 Views)
You can also try setting the transparency to 100% in VI properties > Window Appearance > Custom
 Good luck!
Misha
(3,416 Views)
Why doesnt having "Show front panel when called" UNCHECKED work?
(3,337 Views)
Because that setting is for VIs called as subVIs and your VI is not a subVI.
___________________
Try to take over the world!
(3,324 Views)
