why do i get a daq hardware configuration required window when trying to run the daq solution wizard?
i have recently installed the ni 4552 for pci dynamic signal analyser, and am attempting to configure my system and teach myself labview. when attempting to run the daq solution wizard i am presented with the daq hardware configuration required window.
(2,756 Views)
Have you installed NI-DAQ and NI-DSA?
If not, you can download them from our website under the Drivers section in Downloads.
Let me know if you still encounter problems after installing the drivers.
Brian
(2,756 Views)
hi brian, thanks for your help. i have recently received version 6.1, and done a complete re-install. i have also downloaded the latest ni daq (6.9.2) and ni dsa (6.11) versions and installed them, but still i get the same error message when trying to open the solutions wizard (please see attached powerpoint presentation).
upon selecting the "go to ni daq config utility" option MAX opens. everything appears to be in order (device passes test, test panels run ok and virtual channels are configured correctly). i am unable to go any further.
i would appreciate any guidance that you are able to give me in this matter. many thanks in advance of your help.
best regards,
ben halkon
(2,756 Views)
