hi brian, thanks for your help. i have recently received version 6.1, and done a complete re-install. i have also downloaded the latest ni daq (6.9.2) and ni dsa (6.11) versions and installed them, but still i get the same error message when trying to open the solutions wizard (please see attached powerpoint presentation).
upon selecting the "go to ni daq config utility" option MAX opens. everything appears to be in order (device passes test, test panels run ok and virtual channels are configured correctly). i am unable to go any further.
i would appreciate any guidance that you are able to give me in this matter. many thanks in advance of your help.
best regards,
ben halkon
