why does this two loops have different upshot !thanks
check attatched !i called toolbar ActiveX to realize manipulating of the buttons , but I got two different upshots with both loops ,why? thanks in advance
(2,415 Views)
In the lower loop, the value reference is only read once before the loop, so the value feeding to the case structure will never change once the loop starts. In the upper loop, you read the value reference at each loop iteration.
Think dataflow!
What are you trying to achieve?
(... and don't forget to place a small wait inside each while loop ;))
(2,386 Views)
thanks all the people , I got it,you are hospitable
(2,363 Views)
