why font dialog window popups when running this vi?
1) Press and hold ctrl+R keys.
2) In few seconds, the font dialog window popups immediately.
Why this happens? Is this a bug?
Am using LabVIEW 8.5 and Windows XP SP2
(3,056 Views)
The font dialog window doesn't appear on my WXP SP2 running LV8.6... but it does with LV8.5.1.
Message Edité par JB le 10-28-2008 12:30 PM
(3,050 Views)
Message Edited by mathan on 10-28-2008 06:31 AM
(3,044 Views)
Could somebody please explain me the highlighted portion of the attached image? I don't know how to set it?
Message Edited by mathan on 10-28-2008 06:34 AM
(3,037 Views)
Accepted by topic author Mathan
You have called this dialog yourself from your code 😉
You have sent 0x30 Virtual Key code directly to keyboard via keybd_event function from user32.dll.
So, now you run your VI with Ctrl+R. So, control is pressed, then keybd_event call coming (with 0x30, which is actually key code for 0), so, now you have shortcut Ctrl+0, which is font dialog. No magic and no bug. On my PC its sometimes appeared, sometimes not (race condition between events from keyboard and keybd_event call).
best regards,
Andrey.
(3,034 Views)
Kudos for you andrey. But why JB can't able to reproduce this in LabVIEW 8.6?
(3,031 Views)
Because this "trouble" depends from timing. When Ctrl+R keys pressed, then this key combination will be entered into Windows messaging queue. Now your call for keybd_event coming. This call should be entered also in the queue, and then Ctrl+0 combination will be simulated or not depends from the interference keybd_event call with windows keyboard queue.
I am able to reproduce this behaviour only when Ctrl+R pressed AND block diagram is active. Then Diagram Font Dialog appeared.
Andrey.
(3,026 Views)
