why is there an error when i try to connect a control in the DO lines to NI Elvis writer under case structure?
So frm selecting the acquire signal, i will select Digital Input>Lines then select the channel right? I selected Port0/line0,port0/line1,port0/line8 and port0/line9..are these right?
Message 21 of 26
(855 Views)
I thought you only wanted one digital output related to your LED.  ??
If so, then just pick that one.  Such as Port0/Line 0 assuming that is the line your LED is wired to.
Message 22 of 26
(854 Views)
And why would you select a digital input if you wanted to turn an LED on or off? You need an OUTPUT to do this.
Message 23 of 26
(852 Views)
Because my overall circuit has a 555 timer. So i put the DIO to the trigger and the LED to the output of the IC. So now, im trying to do make a connection where i can compare the DIOs.
Message 24 of 26
(849 Views)
Well, that has nothing to do with the example code you posted or the error so at this point, I really have nothing more to say.
Message 25 of 26
(845 Views)
the example code that i sent is actually the code for the whole circuit..but thanks alot for your help tho!
Message 26 of 26
(842 Views)
