why is there an error when i try to connect a control in the DO lines to NI Elvis writer under case structure?
And if i do this, i do not need a case structure then?
Message 11 of 26
(1,256 Views)
I doubt you'd need a case structure.  Your attached VI had another boolean, but it wasn't clear what the purpose of that was.  So you might need a case structure for that one.
Of course it can be connected to the Elvis Writer.  But your VI showed an array going to the Elvis stuff, but your description was only talking about 1 LED.  What are the other lines for?
Message 12 of 26
(1,250 Views)
the extra boolean control connected to the LED is something extra as the led im trying to control is just one which is a physical LED. And the other lines are just to meet the case structure's requirements to run the program. Btw, i've replace the result with the Elvis writer but it still says it:
These cannot be wired together because their data types (numeric, string, array, cluster, etc.) do not match. Show the Context Help window to see what data type is required.
The type of the source is boolean (TRUE or FALSE).
The type of the sink is 1-D array of
this is the error
Message 13 of 26
(1,247 Views)
I runned the programmed and used a Build Boolean in between of the result and Elivis writer but this error occured;
Specified read or write operation failed, because the number of lines in the data for a channel does not match the number of lines in the channel.
If you are using the Digital Waveform datatype, make sure the number of lines in the digital waveform matches the number of lines in the channel. If you are using boolean data, make sure the array dimension for lines in the data matches the number of lines in the channel.
Number of Lines in Channel: 8
Number of Lines in Data: 1
Task Name: _unnamedTask<4>
what does this mean??
Message 14 of 26
(1,242 Views)
The explanation is quite clear. You have evidently defined the task with 8 channels but the data you are passing only has a single element. So, either your task is incorrect or the data is.
Message 15 of 26
(1,229 Views)
I still cannot solve the problem. With the circuit of multiple AND and the 2 index array, i am still having the error!
Message 17 of 26
(1,203 Views)
What did you change? Did you alter the number of channels in the digital task? If so, to what?
Message 18 of 26
(1,200 Views)
I changed it to different IO ports. But still cant. Actually i am still very confused with  the number of channels in the digital task...><
Message 19 of 26
(1,196 Views)
It should be simple. Each line is a channel. If you want a single line to match your code, you would just specify digital output 0 for example. Don't select a port since that is multiple lines.
Message 20 of 26
(1,194 Views)
