12-18-2012 11:32 PM
So frm selecting the acquire signal, i will select Digital Input>Lines then select the channel right? I selected Port0/line0,port0/line1,port0/line8 and port0/line9..are these right?
 RavensFan
			RavensFan
			12-18-2012 11:38 PM
I thought you only wanted one digital output related to your LED. ??
If so, then just pick that one. Such as Port0/Line 0 assuming that is the line your LED is wired to.
 Dennis_Knutson
			Dennis_Knutson
			12-18-2012 11:45 PM
12-18-2012 11:52 PM
Because my overall circuit has a 555 timer. So i put the DIO to the trigger and the LED to the output of the IC. So now, im trying to do make a connection where i can compare the DIOs.
 Dennis_Knutson
			Dennis_Knutson
			12-19-2012 12:04 AM
12-19-2012 12:29 AM
the example code that i sent is actually the code for the whole circuit..but thanks alot for your help tho!
