Showing results forΒ
Search instead forΒ
Did you mean:Β
why labview class inherit makes me confused, help?
I just make a tesk to know lavbiew class how to inherit, But the result make me confused,I make a picture like below:
"sub1" class inherit from "main" class, isn't it should comeout the "main.lvclass" in the dialogue box??? I'm using labview 2023Q1
(1,424 Views)
Accepted by topic author wen151
Hi Wen,
This is expected.
There is a difference between the wire type and the runtime type.
"To More Generic" simply adapts the wire type to the generic class, but does not modify the runtime type, so internally it stays as a "Sub1" object.
RaphaΓ«l.
(1,391 Views)
If you check help on the wire it should say main.lvclass
Qestit Systems
Certified-LabVIEW-Developer
(1,387 Views)
Thank you very much ,I know it nowπŸ˜€
(1,320 Views)
