why my printer does not work?
Last week, our administrator changed the printer. I also changed the printer name in my Labview program to be the name of the new printer he installed . it did work at first. I've printed out two graphs with this new printer. But suddenly, it didn't work again. the error is 'invalid printer name'. What are the most possible reasons that a printer refuse to work in my LABVIEW program?
Message 1 of 10
(4,512 Views)
I found this Knowledge Base on NI's website which seems to be an issue similar to yours. It suggests using the full path for the printer instead of the alias name and that this can sometimes solve the issue that you are facing. I hope this helps you out.
J.R. Allen
Message 2 of 10
(4,512 Views)
I did in this way. I just copied the printer 's name from properties to my LABVIEW program. and It did worked for sometime. I did printed out two graphs of my LABVIEW progarm
Message 3 of 10
(4,512 Views)
the error code is:
-2147352567
Message 4 of 10
(4,512 Views)
the erroe code is:
-2147352567
Message 5 of 10
(4,512 Views)
I'm not exactly sure what this error means, but I have seen it occur with Report Generation applications. The issue was resolved just by recompiling the VIs. To do this, hold down Ctrl and Alt buttons and click the Run button. You won't see anything happen but you will have to save the VI again. Try this and see if it works for you.
J.R. Allen
Message 6 of 10
(4,512 Views)
Thanks JRA.
Message 7 of 10
(4,512 Views)
I did as you told, but it did not work yet.
The strange thing si that I did succeeded printing out several times before I chnaged the printer name and after. But suddenly, it refused to corperate.
Message 8 of 10
(4,512 Views)
the error codes that I found inmy un-working program
Message 9 of 10
(4,512 Views)
the error code are here
Message 10 of 10
(4,512 Views)
