why the signal amplitude changes sosososo much????after i used a filter
i am so puzzled !
i used butterworth coefficient  vi get the fs=8000hz,low frequency 500hz filter coefficient and used in labview vi ,put 50hz sine wave in ,i dont know why the siginal changed sososo much amplitiude ?i just put a pure wave in the filter no noise no other frequency wave !please help me!i think the labview makes me so puzzled!
Message 1 of 8
(3,834 Views)
You didn't wired anything to the high cutoff frequency input so it is using the default value of 0.45 Hz.
Ben64
Message 2 of 8
(3,807 Views)
lowpass filter dont need higher cutoff frequency
Message 3 of 8
(3,801 Views)
You're right, my bad.
Ben64
Message 4 of 8
(3,796 Views)
I'm not sure why, but try using the "IIR Cascade Filter.vi" instead of the "IIR Filter.vi".
Or use the Butterworth Filter.vi which combines the coefficient and actual filter VIs.
Message 5 of 8
(3,718 Views)
dan_u is correct. Use the IIR Cascade Filter.vi
Message 6 of 8
(3,705 Views)
The IIR filter.vi requires coefficients in direct form.
So, in your original code, we should convert the coefficients to direct form VI before passing it to the IIR filter.vi.
BR
Message 7 of 8
(3,683 Views)
yes,u are right man!
Message 8 of 8
(3,641 Views)
