why this vi is not working?
I need to select out the strings that do not contain the character "." in a string array. The attached string should work but didn't. Would someone point out why? Thanks.
Message 1 of 11
(3,617 Views)
try this one
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 11
(3,613 Views)
Thanks PM, but I am using LabView 6.1, could you post your vi in that version? Thanks.
Message 3 of 11
(3,609 Views)
Unfortunately, no as I only have 7.1 installed, so the best I can do is 7.0. I will do that in the hopes that someone will kindly do the conversion from there to 6.1
Putnam
LabVIEW Champion
Message 4 of 11
(3,608 Views)
Thanks PM. I shall be able to look at LV7.0 in another computer system later.
Message 5 of 11
(3,601 Views)
It's late, lost work finding out that someone plugged in my computer to the wrong outlet on the UPS (Doh!) Here, the change is trivial, in fact I left your original in just not connected.
P.M.
big forehead slap!!!
Putnam
LabVIEW Champion
Message 6 of 11
(3,592 Views)
"." has a special meaning in a regular expression. Use "\." instead to cancel the special meaning
(Simply ad a backslash before your period). Try it! 🙂
Check the online help for details on regular expressions. (right-click on "Match Pattern"...help").
Message Edited by altenbach on 06-08-2005 03:02 PM
Message 7 of 11
(3,598 Views)
here it is in 6.1
Joe.
"NOTHING IS EVER EASY"
Message 8 of 11
(3,577 Views)
Thank you all for the quick help. Both vi works great!
Message 9 of 11
(3,566 Views)
Here's a slighly cleaned up version (LabVIEW 6.1). Notice that you can eliminate a lot of unecessary fluff.
  • Wire the offset output directly to the case structure.
  • Use built array instead of "Insert into array", it is much cleaner.
  • etc.
  • Message 10 of 11
    (3,566 Views)
