wierd algorithm required - intellectual exercise
27 years for me.  First learned boolean logic in 1983.
Ben's  34 years + Wayne's 27 years = 61 years and counting
I'll bet the number gets pretty big.
Message 11 of 20
(1,625 Views)
How are we defining "learned Boolean Logic" - I could say I learnt it in 1981. I was fed or I was not fed. I was asleep or I was not. Smiley Wink
I'm about to be retaught it again. Tired and very tired.
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 12 of 20
(1,621 Views)
In my cases I was trained by the US Navy and had to pass a test like
(A + B) + C = ?
A B C ?
0 0 0 0
0 0 1 1
0 1 0 1
1 0 0 1
0 1 1 1
1 0 1 1
1 1 0 1
1 1 1 1
Ben
Message 13 of 20
(1,619 Views)
Ben
When did your teddy steal Christian's wink? - It's scary coming from the bear!!
Message 14 of 20
(1,616 Views)
James,
Story behind Ben's avatar can be found at the bottom of the page.
Message 15 of 20
(1,603 Views)
The number to boolean array is the easy solution if you "no speaky computer talky very wellie".
A programmatically more beutiful solution is to make a small loop, enter the number through a shift register, loop it 32 times (i assume it's a U32/I32 you have as result, else change accordingly), and bitshift right, connect the shifted bit to a case and if true add the loop's I to an array. The result is ofc connected to the shift register.
That'll give you an array with the indexes and use the faster and more resource contraint bit shuffling.
(Technically it gives you the offset, if you want the index you'll need to add 1)
It might look like alot, but it's a very small loop and you can follow the description straight off the bat. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 16 of 20
(1,566 Views)
James W wrote:
Ben
Were you hibernating????:smileytongue:
Message 17 of 20
(1,547 Views)
muks wrote:
James W wrote:
Ben
It winks so infrequently, I must have been blinking every time it winked!! Smiley Surprised
Only showing evil traits when people aren't looking - now that is evil!!
Message 18 of 20
(1,533 Views)
James,
Does this mean you missed the glint in altenbach's eye as well?
Message 19 of 20
(1,522 Views)
Wayne.C wrote:
James,
There ahead of you!
Altenbach's first name is "Christian" - at least it is according to his profile and many of Ben and other people's posts. Smiley Wink
Message 20 of 20
(1,498 Views)
