window glitch in LabVIEW 2013
DaveT,
I see the same effect on my Mac.
Clicking the Use Current Panel Size button on the Window Run-Time Position page of the VI properties dialog seems to cure it.
Then I tried several combinations of panel size settings on that page and the Window Size page. Now I cannot get the problem to come back.
So it appears to be some kind of interaction among those settings.
Lynn
Message 11 of 17
(1,989 Views)
Lynn,
   Thanks for verifying it.  I agree that it's related to some combination of window settings.  I found a few of those earlier, as posted above.  I hadn't tried the Use Current Panel Size fix.  That does seem to help.  Thanks!
   I suspect that this could be a bizarre inheritance from when a LV 2012 VI with certain things set into LV 2013, which is probably why more people aren't noticing it.
DaveT
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
Message 12 of 17
(1,971 Views)
Dave,
What things?  I really hate to belabor you but, there seems to be a CAR needed.   And, I'm always happy to be learning new tricks.
Message 13 of 17
(1,951 Views)
Although I didn't find this when I was first posting, I've now found an older thread discussing this same behavior:
http://forums.ni.com/t5/LabVIEW/LabVIEW-2013-Window-Appearance/td-p/2578039
I'll post another cross-link there to this thread.
Message 14 of 17
(1,929 Views)
This is a known issue which NI is aware of. Currently, there are two workarounds:
1) Change Window Size»Minimum Panel Size Width and Height to 0,0.
2) Check "Use Current Panel Size" box under "Window Run-Time Position."
Hope that helps!
Ryan K.
Product Manager, ATCA and BEEcube
Message 15 of 17
(1,873 Views)
Ryan,
Just wondering if this ever got fixed?
Message 16 of 17
(1,762 Views)
Ian,
I was able to reproduce this behavior in LabVIEW 2015, so I don't believe that it has been fixed, but R&D is still aware of the issue. It seems that setting the minimum front panel size in the VI properties is an easy workaround.
Message 17 of 17
(1,731 Views)
