windows 10 compatability
If a VI was developed on a Windows 10 OS could it be executed/operated on a Windows 7 OS?
(4,037 Views)
Most likely yes.  But always test where possible.
(4,028 Views)
You should be using LV 2015 to develop this application.  You'll find 2015 has Win7 support.  It's expected to work.  But as crossrulz points out, testing is always your friend (even from Win10 to Win10)
(3,989 Views)
In stalled LabVIEW 2015 RTE onto Windows 7 embedded controller.  Downloaded simple VI that was developed on a Windows 10 system the VI worked as expected.  Now I will develop a VI that will exercise the ADC, DAC and GPIO custom interface.
Thank You for your responce
Mike_at_Eltron
(3,958 Views)
