windows 7 application file read/write problems
You were told how to properly do it.
Message 11 of 16
(1,549 Views)
No need to be rude, Mr smercurio.
Just because you are Knight here, does not mean you should go trolling for an argument with newbies.
http://www.medicollector.com
Message 12 of 16
(1,547 Views)
You'll forgive me if I take your criticism with a grain of salt.
Message 13 of 16
(1,537 Views)
ASAT,
Are were you able to get it up and running now?
Ben D.
Message 14 of 16
(1,516 Views)
I -am having the same problem.  I am trying to write a tab delimited text file and it never worked when I have my installer install the exe in Program files location. I then switched the installation to C:\.  It doesn't write there all the time. Sometimes it does and sometimes it doesnt. I finally relented and changed security options on C:\ because this is getting really annoying. The fact is, it is very inconsistent when it comes to writing it to the file. Is there something I can do differently?
I may not be perfect, but I'm all I got!
Message 15 of 16
(1,402 Views)
Hi VeeJay,
by default, everything in Program Files is read-only.
To make a file or folder read/write, you need to specify this in your installer.  See here for instructions:
http://forums.ni.com/t5/LabVIEW/Installer-Help-folder-permissions-inside-Program-Files/m-p/1651488#M...
Message 16 of 16
(1,393 Views)
