windows border padding
it's possible to modify eith labview the windows borders?
I attach the image which I need to set.
thanks
(3,062 Views)
What is that you're having problems with? Is it not working?
(3,052 Views)
I have problem with splitter bar position.
I would to explore some solutions.
Do you know a method to read and write windows borders?
(3,038 Views)
And that problem is?
It's probably a registry setting. You can use Google to find out what it is. LabVIEW has VIs to read/write the registry if it's stored in there. Since you're using Windows 7 watch out for UAC.
(3,010 Views)
