with out synchronizer
when two tasks are accessing same analog channel how to give acces , with out using synchronizer .Smiley Happy
(2,641 Views)
If you are using NI's DAQmx, you can't have two tasks accessing the same hardware channel simultaneously.  You'll get a "resources reserved" error.  You would need to close one task before creating the other, which makes no sense at all.
What, exactly, are you trying to do?
(2,618 Views)
