write a binary file per day // show the samples only 1 in 1 minute
Accepted by EduU
Hi Edu,
If whatever you are reading is generating the "1" or "0", then you can use the Digital Input.
Is it a TTL level (5V) that you are reading?  The DAQ should be configured for that.
It is also possible to use the Analog Input also, where you would read the voltage level and the threshold (for 1 & 0) would be set within the software.
It's probably better with the Digital In.
R
PS:  I may not be able to look at your code until Saturday.
Message Edited by Ray.R on 10-01-2009 05:31 PM
Message 41 of 59
(1,964 Views)
Well Ray.R,
I have to use Digital I/O because I'm already using the 8 Analog I/O
6 to measure voltage and 2 to measure temperature
so I will use the Digital input.. I only have to know why I can do that...
I will study it at work today and will give a try
To simulate a signal 0 or 1 I will put a key on/off only to test if it works
Then I will switch and will see what will happen!
When I arrived at my work, I post more things thanks 😉
Message 42 of 59
(1,953 Views)
In the meantime, here are some paces where you can find more information about the Digital IO and DAQmx.
Look for some examples: Help (menu)->find examples->Hardware Input and Output->Digital Generation.
I just looked for a sample example within LV2009, but they no longer have the Digital IO examples...  😞
Look in LV8.6 if they still have some.  Maybe this installation did not have all of them, it is a trial version that I downloaded.
If you can't find any, I can search in older versions of LV.
You can also look at some online articles that might help you with your project at the following links:
Getting Started with NI-DAQmx: Using the DAQ Assistant
and
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications.
R
Message 43 of 59
(1,949 Views)
You might also find this thread useful
Message 44 of 59
(1,947 Views)
Yes is a TTL that I'm reading!
I talked with my boss today, and he give me some tips on that
I will try now make a simple example here to see if it will work!
I will put a resistor of 2,2KoHm and a key "on/off"
5Vcc - Terminal 31
a resistor 2,2k oHm
between the resistor and the key a wire to terminal 17 P0.0
a key On/Off
a wire to GND - Terminal 32
So I will switch the Key On/Off and see if the values goes True and False!
Is this correct?
Thanks Ray.R
Message 45 of 59
(1,939 Views)
Sounds like a good plan 🙂
Message 46 of 59
(1,927 Views)
Well I did it and works perfectly!
Now I'm waiting my boss, because he will tell me what the next thing to do
Thank you for all the help you give me Ray.R
If I have any other question, I will use this post!
And if you can take a look at my code and maybe fix somethings
or give me some tips to improve it more and more, I would be pleasure.
I voted on you, to the solution of my problem! You helped me so much!
Message Edited by EduU on 10-02-2009 12:16 PM
Message 47 of 59
(1,924 Views)
Hey Ray.R
I have a question, I was sending to another program the data from what I was measuring
It was 3 voltages and 3 currents, but now I want to send the others things
I have 2 graphs that I want to show in the other program via tcp/ip
and have 2 boolean variables... how can I send all these informations??
i will upload a screen shot of how I sent the 3 voltages and 3 currents
I don't know if i only have to put more input at the  build array
or if i have to send it from another way!
I don't know if you have the program yet, so I will upload it again for you
version 8.5 at LabVIEW
The red circles is what I want to send too!
Give me some feedback!
Message 48 of 59
(1,876 Views)
What is the program at the other end of the Ethernet connection?  Is it also LabVIEW?
Message Edited by Ray.R on 10-08-2009 05:59 PM
Message 49 of 59
(1,863 Views)
yeah is a program made with LABVIEW for me
I tryed use a bundle cluster...
But I'm receiving an error at my client.vi
Error 116 occurred at Unflatten From String in teste 4 - client.vi
Possible reason(s):
LabVIEW:  Unflatten or byte stream read operation failed due to corrupt, unexpected, or truncated data.
I will upload the client vi...
So maybe you can take a look
and tell me where i'm commiting a mistake
here are the 2 screen shots from my server and client too:
server:
Client:
Thanks for any help Ray.R!
Message 50 of 59
(1,851 Views)
