write array to serial port
Hi. Too long I can’t solve my problem.  (Please see attached VI)
I need you help again.
I want send to serial port array of numbers (from 0 to 255 decimal). My VI do not want do it. In FOR loop I make my array, but it is don’t  write to port sequentially.
I did something wrong?
Thank you!
Message Edited by Mihalis on 07-28-2005 01:17 PM
(3,389 Views)
Your while loop will only start after the for loop finishes, so you're not sending 0, 1, ..., 255. When your for loop ends (256 seconds) you will convert the array to a string with 256 bytes from ascii 0 to 255.
I changed your vi to send "0", then "1", ... , then "255". Hpe this is what you need.
Paulo
(3,379 Views)
Hi Paulo. Thank you! It is work.
Mikhail.
(3,375 Views)
