write delimited spreadsheet
I'm embarrassed to ask this but I'm terribly rusty with LabVIEW
If I'm outputting a 2D array into the file (Double precision numbers) Every for loop cycle
1 4
2 5
3 6
Using -write delimited spreadsheet Function
I get
1 4
2 5
3 6
1 4
2 5
3 6
After two cycles
What I want
1 4 1 4
2 5 2 5
3 6 3 6
How do I bring the second cycle back to the top of the file in alignment with the first data set?
(1,462 Views)
If performance isn't a concern, you could read the existing contents of the file, do some transposes, and then append the new array.
(1,434 Views)
Accepted by LED47
You can only append rows, not columns. This is a consequence of the file layout.
On disk, the file looks like
1 4\n2 5\n3 6\n
after inserting columns, the file looks like
1 4 1 4\n2 5 2 5\n3 6 3 6
You need to build a larger 2D array in memory by concatenating each cycle’s 2D array horizontally (column-wise), then write the final array to the file once.
build array columnwisebuild array columnwise
The alternative is to change the file layout. Or rewrite the file each iteration.
(1,429 Views)
That's the ticket...
Thank you to everyone
(1,412 Views)
I agree, change your code to append two rows with each iteration and document it. Even for a gigantic file, no existing data needs to ever be touched.
In particular, use low-level file i/o, open it before the loop, keep appending in the loop, and close when done.
You can always add a postprocessing step that generates the transposed file at the very end.
(1,363 Views)
