write to excel 2013 file
dear member
 i have this LV 2012 VI that has two inputs and two outputs
i want to record them in EXcel file
as following in each row
seed1 seeed2 mean variance
and in my case thier will be about 200,000,000 rows in the excel file
 the VI http://www.4shared.com/file/TJzJCb-B/seed1seed2.html
here du to that NI attackment error whith the following "The contents of the attachment doesn't match its file type"
i try to use .rar but same thing
any change in my Vi will be appreciated
please i need help in this
hi ?Q>
(4,120 Views)
You can find an example for writing to Excel in https://decibel.ni.com/content/docs/DOC-2081. However, Excel limits row to 1047568 row/sheet. You may need to separate data into multisheet.
(4,089 Views)
As mentioned above, Excel is out, because of the row limit.
What is the purpose of the file. Does it need to be read by other programs?
Writing 200 000 000 rows should NOT be done in ASCII or excel, but should be saved as a binary file. Much less overhead!
(4,086 Views)
thank you for advise
hi ?Q>
(4,062 Views)
The item does not exist. It may have been deleted.
hi ?Q>
(4,060 Views)
The link was corrupted by the period at the end.
The correct link is https://decibel.ni.com/content/docs/DOC-2081
PS:
What does "hi ?Q>" mean in your signature?
(4,037 Views)
