write to measurement file pda
hi, ive been learning labview on v.7.1 and now im trying to create simple programs on labview pda 8.21.
i want to continually record a signal to text file like an lvm. i was previsously just using the 'write to measurment file' function and connecting my simulated signal straight to it. now when i try to run it in a windows 2003 mobile emulator i get the error 'subVI is not executable'
what would be the best way of getting around this? as this is a big sticking point for my project.
thanks alot
andrew
Message Edited by lav on 03-17-2008 07:47 AM
(2,525 Views)
Hi Andrew,
I hope you are well.  Thanks very much for your post.  I have taken a look at your problem and I think it may be due to some incompatabilities between LabVIEW and the PDA that you are using.  I was wondering if it would be possible for you to post the code on the forum so that I can take a closer look at it to try resolve the problem.
Thanks very much.
Kind regards,
Prashant M
Applications Engineer
NI UK & Ireland
(2,465 Views)
