writing 2d string to excel file
When I try and put my table into an excel the message pops up and I cannot open the file. The path is correct.
CLD Certified 2014
(3,334 Views)
The "Write To Spreadsheet File.vi" writes a text file and not an excel file. You could use the report generation toolkit
https://www.ni.com/en/shop/labview/select-edition.html or maybe, with modifications, http://decibel.ni.com/content/docs/DOC-2081.
JM
(3,329 Views)
Try the example:
C:\Program Files\National Instruments\LabVIEW 8.6\examples\comm\ExcelExamples.llb\Excel Macro Example.vi
JM
(3,322 Views)
Accepted by ADrexelDragon
Actually, a better example would be Write Table to XL. Just use the Example Finder (Help -> Find Examples) to find it. You can also peruse the Excel thread for lots of links to other examples on how to control Excel from LabVIEW.
(3,308 Views)
Try to save it as Book1.xls. Put this filename in the path.
But this method of using spreadsheet is not good in feature wise.
As in the above messages the examples are quite good.
Regards
shrek
(3,300 Views)
