writing array of time strings to excel
Hello, and thank you in advance for any help.
I am writing a 2-D array of strings to an excel sheet.  The first collumn of the array contains time strings in the form hr:min:sec.xxx (xxx being fractions of a second.  For some reason, when I open this in excel that first collumn is wrong.  Even if I format those cells as Time, it will leave out the fractions of a second which it displays fine in labview.  Can anyone offer advice on how to recieve the correct data in excel?
Attached is how I write the time string and how I write the 2-D array to a spreadsheet file.
Thank you,
Steve
(3,288 Views)
your vi is right
In excel, right click to format the cells, under Number, select Custom from the category list.
enter hh:mm:ss.000 into the type box
there ya go! Smiley Happy
2006 Ultimate LabVIEW G-eek.
(3,278 Views)
Thanks 🙂
Do you know of a way to send that formatting command through labview??
(3,273 Views)
The short answer is yes.  I know you can do it through ActiveX controls (there's a Property Node for the active workbook's active sheet's cell range called Number Format where you simply wire the above format).  The problem is that you seem to write a file and then open it up in excel independently, versus populating excel via labview (there's shipping examples of this).  But it seems like a lot of work to go through, and I can't dummy one up at the end of the workday Smiley Wink
Maybe someone else has a better idea?
Message Edited by Jonnie 5 on 08-08-2006 05:01 PM
(3,269 Views)
The problem is you are not writing a true excel file. You are writing a tab delimited file and giving it a .csv extension so that excel will open the file when opened inside windows. You can cure your problem a couple of ways.
  1. Use activeX and write to excel directly (not recommended)
  2. You could creat a Macro in excel that will do the formatting for you.
I would use the later of the two.
Why are you so worried about fractions of a second being displayed anyway?
Joe.
"NOTHING IS EVER EASY"
(3,254 Views)
