writing data to the csv data sheet
Dear all: i have project using sbrio as hardware i am running my program using fpga and real time program, my problem as follows, i collect all data i need to record in my target as csv data sheet files my problem that the writing data to the csv inside the main whle loop of the the all real time program that is make my program running in different frequency required form the timming loop for ex. my timming loop is 100 Hz but actually it seems to me running at 20 Hz, i feel that done due to using writing the data in that loop is their any way to overcome that problem for ex. writing the data outside the main loop or any othet way hopefully find examples solved that problem, thanks for help
(3,046 Views)
You posted in the MathScript forum. Are you looking for a MathScript or plain LabVIEW solution?
(3,044 Views)
LABVIEW REAL TIME DISCUSSION FORM
(3,041 Views)
No need to shout! (... or please fix your capslock key)
Currently we are in the very specialized forum for LabVIEW Mathscript RT, which is definitely not right for your question.
LabVIEW RT is handled in the plain LabVIEW forum.
Please ask the moderator to move this thread to the right place (look for the options menu in the upper right of your post to contact a moderator)
(3,037 Views)
Producer/Consumer
Use a Queue to send data from your main loop to another loop that does nothing but log the data.
(3,006 Views)
