writing ramp functions
Hello All,
I'm attempitng to implement some ramping functions for writing to a PCI 6711 analog output board.  There will be many times throughout the experiment where ramping is not necessary, they can just be a static voltage change.  I've attached an excel spreadsheet that tries to breakdown how the array should look within the program, and also what the user would enter in to get this outcome.  I have also attached some code where I tried to implement a ramping function but I can't quite get it to work.  I believe there may be an issuer with using the PFI as a sample clock, perhaps writing a high to a PFI line could trigger one of the analog counters which could produce enough rising edges to output the data correctly.  If anyone can see where my code is going wrong in building the array, that would be very helpful.
Steve
Message 1 of 15
(5,506 Views)
no files are attached
Message 2 of 15
(5,501 Views)
Sorry, it gave some strange error about too many posts
Hopefully it goes through this time
Message 3 of 15
(5,499 Views)
I had to do a very simple single voltage ramp the other day. This was my solution... maybe it will help.
Edit: The 1000 you see wired all over the place is the sample clock rate. I basically did everything in ms for simplification.  That middle for loop is the one that actually does the ramp.  The other two are just wait times at top and bottom of the cycle.
Message 4 of 15
(5,469 Views)
I'm on labview 2011, could you screen shot it quick?
Message 5 of 15
(5,464 Views)
Edit:  My math may also make more sense if I told you that the first division (Target Press / 1000) was conversion from pressure (0..10,000 scale) in to voltage (0..10 scale).  The way the math worked was:
1: Find voltage range you are ramping over (V_final - V_initial)
2: Find how long it will take to do that given ramp rate (V_f - V_i) / (rate)
3: Multiply by 1000 to get it in to ms
4: For each ms, voltage = i*dV + V_i
Where dV = voltage range / number of points.
Message 6 of 15
(5,459 Views)
Why didn't you just use the Ramp Waveform VI?  It would be so much easier.
Message 7 of 15
(5,416 Views)
Well, since you asked... I have a tendancy to do simple math like this myself in most cases. I trust it more, I know exactly how it is going to act in situations, and I find that it easier and takes less time for me to just program it than it does for me to load up the help, figure out exactly how the VI works, and then dump it in.
Message 8 of 15
(5,366 Views)
I guess in real life you would make all that into a subVI?
Bill
CLD
(Mid-Level minion.)
Message 9 of 15
(5,358 Views)
If this hadn't been a one time use quick program, yes.  It would be a sub-vi and all of the "1000" constants would be variable instead.
Message 10 of 15
(5,353 Views)
