writing to one digital channel and reading from other
I am working on 9074 cRio, and have a 9401 digital I/O module. I wrote a very simple program, in which i write a logic one to a digital output line and i physically wire this digital out put line to another digital input line and read it in program.
-I connected channels DI/O-1 (used as outputline) to DI/O-2(used as input line)  of same 9401 module with a same wire Its a very simple program but i don't understand where things are not working out. Please help me out.
(3,096 Views)
I learnt that the 8 channels are divided into two ports (0 to 3) and (4 to 7). and all port lines should be having same line direction. So i changed this time the input channel from D2 to D5.
Still when am reading the input port i am not getting a logic one
(3,084 Views)
I have to ask the stupid questions:
Did you move your wire so that channels 1 and 5 are connected?
Are you sure you connected the right pins?
GCentral
(3,064 Views)
🙂 Sir that was indeed a wise question to ask.
All connections and confugrations are correct. To my surprise i just discovered that the problem was with the power supply from which i am taking ground for 9401. I jst changed the power supply and its working fine. Thank you
(3,045 Views)
