xy graph cutting data
 I would check if this anomaly was really systematic, e.g. does this look always the same over a certain period of time e.g. one week?
Message 21 of 36
(4,669 Views)
I put a 1.5v (AA) battery on the 9215 and got this....Is there anyway I can calibrate this daq to make sure it's still within spec?
Message 22 of 36
(4,663 Views)
I'm on a laptop as well.
Message 23 of 36
(4,661 Views)
Here's what the 1.5 looks like in MAX.
Message 24 of 36
(4,648 Views)
That looks suspiciously like power line pickup.  How do you have everything connected, especially grounds?
Lynn
Message 25 of 36
(4,617 Views)
What grounds do you mean? The 2 AI grounds are going into the AI- ports on the 9215. There's nothing special set up...I'm pretty sure it's the DAQ because my DOS scope reads the 2 channels fine.
Message 26 of 36
(4,610 Views)
and for the AA battery I simply put the leads coming out of the DAQ in their respective polarities on the battery.
Message 27 of 36
(4,608 Views)
Accepted by topic author glskinner84
Try connecting the source to COM as shown on Figure 5 (below) or Figure 6 of the NI 9215 Operating Intructions and Specifications document.
Lynn
Message 28 of 36
(4,595 Views)
I'll post results of my attempt at your suggestion after lunch, John.
Message 29 of 36
(4,537 Views)
It seemed to cleanup the signal but I'm still getting a weird offset.
Message 30 of 36
(4,526 Views)
