xy graph won't display
I have a problem with the xy graph not displaying. Tried nearly everything that I know of. The graph simply won't display the two arrays. I tried building an array of clusters into the graph and that didn't work. attached is what I am trying to do. Something simple for my class involving equation of motion and the mathscript. Any help would be greatly appreciated.
(2,814 Views)
Can you post the actual VI so someone does not have to try to duplicate the script?
Also, have you probed the output of the script to see how many elements are in the arrays?
(2,803 Views)
Accepted by fooku
where do you define y0?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(2,776 Views)
I think your graph is just plotting one point. (x,y)
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(2,773 Views)
maybe you could use a chart to display the data
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(2,766 Views)
