xy pairs to waveform
If there ever will be a "race for code"? 😄
Maybe the number of wires per minute? 😄
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 11 of 18
(1,843 Views)
Sheesh.  I hope not.  I'm REALLY slow.  Robot Sad
I like to think of myself as more turtle than hare. Robot Happy
Message 12 of 18
(1,839 Views)
You know the fairy-tale about the rabbit and hedgehog? I think this could also be aplied on turtles. 😉
Using LV8.0
Message 13 of 18
(1,836 Views)
This is a good bit of useful code.  This is a very common problem of converting nonuinform sampling to a waveform (unless you are using DAQ where samples are timed using a clock).  I am supprised that there is not a function to do this already.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 14 of 18
(1,834 Views)
In think in LV7.0 there are also some interpolation functions, but not that comfortable as these in LV8.0.
Using LV8.0
Message 15 of 18
(1,831 Views)
Hi Jason,
    do you know how to do this with LV 7.1? I mean converting an XY graph into a waveform graph. Do you have a sample in LV 7.1?
Message 16 of 18
(1,653 Views)
Look for some resample waveform examples. I found one that will take XY pairs and convert to waveforms.
C:\Program Files\National Instruments\LabVIEW 7.0\vi.lib\measure\maresamp.llb\Resample Array of Pairs (single shot).vi
Message 17 of 18
(1,648 Views)
   I've found it but it doesn't work. I have a waveform in which I want to get the envelope. I've already found a demo in the disscussion forums where I can get this envelope (attach, Envelope.vi). The input of this VI is a waveform. On the other hand I have created another VI (also found from the posts) in which I add a circle of a configurable ratio to each point of my waveform. This help me to adust the limits of my measurement. The objective is to get the envelope of the "XY Graph Circles" using the Envelop.vi. the problem is that the Envelop requires waveform data and my graph is represented XY.
Do you have some idea to connect those to VIs?
Thanks in advance,
AOC
Message 18 of 18
(1,632 Views)
