yellow exclamation mark next to project item
Hello everybody,
I have a project that somebody else starts. Now I have to open the project but when I open I see a yellow exclamation mark before the TPC (touch panel) item. How can I solve this problem. Which Labview component I have to install to see the content of this item. The item is in fact a NI touch panel. I put the screen attached.
I use Labview 2013.
Best Regards
(2,285 Views)
Accepted by topic author Mehmet_SARIKOÇ
Thanks everybody.
I have just found the problem. Before Labview 2014, Labview Touch Panel Module is not included in Labview Development System. So I have installed Touch Panel Module 2013 and now the problem is solved.
(2,275 Views)
