zero fill string
I am converting a decimal string into the binary equivalent using the format into string function, just wondering if there is a way to left zero fill the results?  For example I have  5 converted to 1001 but would like to have the output string as 00001001, thanks.
(4,405 Views)
After the part you have accomplished (5 -> 1001), measure the length of the converted string and concatenate the desired number of zero characters at the beginning of the string.
Lynn
(4,399 Views)
Accepted by svt4cobra6
format string
%08b
Ben
(4,394 Views)
thanks for the replies, changing the format specifier worked.
(4,389 Views)
You wil use format into string function with format string "%08b". The zero tells to pad with zeros on left. The eight tells the number of digits and b convert to binay.
(4,388 Views)
Good.
BTW
5 ===> 101
9 ===> 1001
now Ifeel better. Smiley Wink
Ben
(4,384 Views)
yep thanks for the correction on the binary math!
(4,370 Views)
