zero waveform array
My application acquires data and displays it on a waveform graph.
When I make a second run, the previous run's data is displayed on the plot (I want only the most-recent run to be displayed).  This behavior is not a problem if I close and then open the application before making the second run.
The displayed data is written to a waveform array indicator (for additional processing functionality).  I think I need to zero the waveform array data in the indicator to alway have a fresh plot.
What is the best/easiest way to do this?
TIA
Ken
(3,347 Views)
Waveform graphs don't retain data. Do you possibly use a waveform chart?
With a chart, you could write an empty array to the "history data" property node at program start, or simply reset the chart to defaults using an invoke node
(3,341 Views)
Hey Custom,
Here is a VI that demonstrates the different behaviors between the waveform graph and the waveform chart. You can also turn on and off the chart history. It simply uses a property not with the history being changed. I hope this helps.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,318 Views)
Here is a modified version that allows you to run continously.
jigg
CTA, CLA
testeract.com
(3,317 Views)
Thank you Sam and Altenbeck.
Your responses were helpful!
I used the Invoke Node to reset to defaults .
(3,301 Views)
