Convert time to second and put this to an oaix of 3d graph
Hi
I need to get the time of time system and then writing this time into an aix of  a 3d graph.
I am having problems.
I was trying to  get the time,then pass to seconds,or get thetime in seconds,multiply by a constant and write to tge aix,but i am not having any result.(I need to show the time in graph in hour:minutes:seconds)
I have already use the properties of 3dgraph and discover that i need to multiply the hour ( but i need in format of number) to show the hour in format og hh:mm:ss in 3d graph.
It is confuse?
I am sending the vi.
Another problem only to detail more: i will not have the rang of the aix in hour:minutes:sconds,because the time of the beginning and the the time which will finish alway will change. (I thought in put this aix in autoscale)
I can explain more. (The aix of tme is aix X in my example)
Please help me!
Rafael
Labview 5.1
Brasil
Message 1 of 15
(3,620 Views)
Anybody could help me???
Thanks a lot
Rafael
Brasil
Labview 5.1
Message 2 of 15
(3,606 Views)
You'll find your answer in the following thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=71153&requireLogin=False
Basically, you just have to calculate the number of days (fractional days will give you the hours, minutes, and seconds) from 12/30/1999 00:00.00.  Further details are in the thread above.
Best Regards,
JLS
Best,
JLS
Sixclear
Message 3 of 15
(3,590 Views)
After consulted your link and many attempts i have a doubt.
I get the time and date with the function get date/rtime (string) and i know now how to pass to the right value to the 3d graph.
But i need to know how can i pass the time/date (string) to seconds and the i will multiply by values and write in the 3D graph.
Plese help me
Thanks a lot
Rafael
Labview 5.1
Brasil
Message 4 of 15
(3,569 Views)
Oops!!!
Anybody help me please!
Thanks a lot
Message 5 of 15
(3,555 Views)
I do not have Version 5 loaded on any machines anymore so I took screen shots.
OK Here is your block diagram
Paul
Message 6 of 15
(3,538 Views)
Here is your front panel
Paul
Message 7 of 15
(3,537 Views)
Lastly, VI in LabVIEW 7.1.1
Forgot to attach
Message Edited by Pana-man on 10-11-2005 08:53 AM
Paul
Message 8 of 15
(3,537 Views)
Hi
I tried to do this,but in labview 5.1 is a little different.
My difficult now is to put the time and date 00:00:00.000 1999/31/12.I did not find this time stamp.
Could you help me??
I am doing what you recommended but for labview 5.1 .
Thanks a lot
Rafael
Brasil
Labview 5.1
Message 9 of 15
(3,492 Views)
Hi.
Sorry if i am sending many messages,but this graph 3d for me and for tge people of my lab it is new,and i need this urgnetly.
Anyone could help.
I have 3 doubts but i will be thanked if you someone answer my last message.
Thanks a lot
Rafae
Brasil
Labview 5.1
Message 10 of 15
(3,478 Views)
