ā11-12-2010 12:15 PM
I'd like to be able to send my design to NI support when I have a question so that the
apps engineer can see what i'm trying to do. Is there an easy way within the LV
environment to zip all or part of a design heirarchy?
ā11-12-2010
02:21 PM
- last edited on
ā12-17-2025
02:26 PM
by
Content Cleaner
Do you have access to the Application Builder? If so, you can use the Application Builder to build a zip file. Here are the instructions:
Building a Zip File [topic no longer available in help]
ā11-12-2010 02:37 PM
Unfortunately I don't have the application builder. Is there anything else I could try?
ā11-12-2010
03:27 PM
- last edited on
ā12-17-2025
02:27 PM
by
Content Cleaner
If you want to build a zip file without using the Application Builder, you could use the Zip VIs. But, you will have to know the relative path for every file you want to include in the zip file to use these VIs.
Otherwise, what you could is probably build a source distribution. You can then zip it and send it over to anybody.
Building a Source Distribution [topic no longer exists in help]
