zip design
I'd like to be able to send my design to NI support when I have a question so that the
apps engineer can see what i'm trying to do.  Is there an easy way within the LV
environment to zip all or part of a design heirarchy?
(2,952 Views)
Do you have access to the Application Builder? If so, you can use the Application Builder to build a zip file. Here are the instructions:
Building a Zip File [topic no longer available in help]
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,932 Views)
Unfortunately I don't have the application builder.  Is there anything else I could try?
(2,932 Views)
If you want to build a zip file without using the Application Builder, you could use the Zip VIs. But, you will have to know the relative path for every file you want to include in the zip file to use these VIs.
Otherwise, what you could is probably build a source distribution. You can then zip it and send it over to anybody.
Building a Source Distribution [topic no longer exists in help]
Adnan Zafar
(2,928 Views)
