 Laser
			 on
		01-07-2014
		01:28 AM
			2 Comments (2 New)
			Laser
			 on
		01-07-2014
		01:28 AM
			2 Comments (2 New)
in many of my applications, I have to verifiy some conditions recursively and they can generate an error, for example when checking the presence of a file (see below).
Imagine to have a task doing this control and imagine the task is scheduled every 5 seconds or less.
This means you'll get the popup window continuosly and it makes almost impossible to debug your code.
I know I can reduce the Debugging level from Extended or Standard to No RunTime Checking in order to block that popup window, but sometime I need a deeper level of debug to fix my problems.
What do you think about adding a third button to ignore, for the current debugging session only, the run time errors generated from the same instruction in the same thread?
More, what do you think about adding a fourth button to ignore, for the current debugging session only, the run time errors of the same type?
Regards
Sergio
