LabWindows/CVI Idea Exchange
Al.B
Control ID parameter in UI functions (SetCtrlVal, etc) should have access to the select constant dialog in the function panel
Status: New
When using the UI functions, a neat feature is the ability to pull up a dialog of valid control IDs when specifying the control:
undefined
clicking the elipses displays this dialog showing all valid control IDs:
undefined
If you are using the function panel however, you cannot access this dialog and you are on your own for figuring out the correct control ID:
undefined
I think we should add this functionality in the function panel for any function that has a control ID parameter.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
4 Comments
Wolfgang
Trusted Enthusiast
...and similarly one could possibly also consider providing an ellispis for the panel handle - including tab panels
Al.B
NI Employee (retired)
Hi Wolfgang,
I agree, that would definately make things easier!
Al B.
CTA/CLD
RobertoBozzolo
Proven Zealot
The Select UIR constant panel is shown simply pressing Enter while on 'Control ID' field Smiley Wink
LuisG
Wolfgang,
The panel handle can't use the same mechanism since you would most likely want to use a variable for that parameter, not a UIR constant name (unless you're referring to the last parameter of LoadPanel, for example, in which case you can also press <Enter> as Roberto indicated.
You can, however, press <Ctrl-A> on any input control of a function panel and select one of your project variables to copy into the control. This can be used for panel handles.
Luis
