If one is interested in having a popup menu that shows up only for row or column headers it would be convenient to have the analogon to the event EVENT_TABLE_ROW_COL_LABEL_CLICK (which actually is a EVENT_TABLE_ROW_COL_LABEL_LEFT_CLICK event...), i.e. I am suggesting an event that is fired when a right click is received on a table column (or row) label.
It should be added that right now this is already possible with 11 additional lines of code, see the example colview, so I do not consider this idea as urgent
, but still...
