I want to change the background color on a Ring Control drop down portion using the "paint tool" and then selecting the operate tool in the Quick Edit Window. When I select the "operate tool" to look at the background color of the drop down portion of the ring control it is always "light grey". Even if I change the color of the ring control using the paint tool the drop down background portion still remains "light grey".
Provide a mechanism to allow the changing of colors to the drop down portion of the ring control to be changed programmatically also. The current version of CVI 2010 does not provide this capability.
