LabWindows/CVI
软件打包的问题
软件在开发完成之后,打包。。。。。结果安装文件安装完成之后,菜单图标显示不了,这是什么问题呢?谢谢!
(3,341 Views)
English Translation:
After the software development was completed, an installation package was created.
The problem is that after the installation package installed the application, there is no menu icon appearing.
Thanks!
(3,322 Views)
When you create the installer, do you include the path to the icons that you want to include in your software distribution?
In other words, are you including the icons?
It appears that it finds the icons on your development system because they exist on your PC.  If they are not included in your distribution, then your application will not know where to obtain them.
当您创建安装程序,你包括的图标,你要包括在您的软件分发的道路?
在,你包括图标换言之?
来,找到您的开发系统上的图标,因为他们在您的PC存在。如果他们不包括在你的发行,那么你的申请将不知道从哪里得到这些。
(3,321 Views)
